Message 11 of 16
Re: New User Speed
please keep us posted on progress
stuteman
Message 12 of 16
Re: New User Speed
Still going strong but only at 2 Meg. Hopefully mods will be able to help soon.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:5 days, 14:34:38
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):11.9 dB / 25.0 dB
Line attenuation (Down/Up):19.5 dB / 7.5 dB
Output power (Down/Up):19.9 dBm / 12.3 dBm
FEC Events (Down/Up):0 / 1
CRC Events (Down/Up):990 / 13
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):24011 / 1
Error Seconds (Local/Remote):450 / 50
Message 13 of 16
Re: New User Speed
just need patience the mods will contact you but just keep checking btspeedtester for any change
Message 14 of 16
Re: New User Speed
just keep checking the speedtester and wait for the mods who will get it resolved for you
stuteman
Message 15 of 16
Re: New User Speed
Quick update. Mods sorted it out and for that I'm glad.
However, it should be possible to resolve these "stuck" profiles more quickly.
Thanks to all involved.
Message 16 of 16
Re: New User Speed
You were still in the basic 10 day line training period normally no resets will be done until that time has completed
normally a stuck profile will reset automatically within in 3/5days once the exchange equipment sees the line as stable there is no point in doing a manual reset before this time as the profile will just drop again within a few hours if the line is not stable
