stuteman
Message 1 of 16
New User Speed
I have had service for nearly 5 days now and I appear to be stuck at 2 Meg.
Download speedachieved during the test was - 1.8 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
I have been away from BT for a couple of years but when I was last with them I was getting 6 or 7 meg,
Is this a stuck profile and what can I do about it?
15 REPLIES 15
Message 2 of 16
Re: New User Speed
it could be a stuck profile.  could you post your router stats please
stuteman
Message 3 of 16
Re: New User Speed
Router stats. The disconnection 1 day 4 hours ago was due to a someone pulling out the plug to plug in a hoover !!. We have been connected sucessfully since last Wednesday apart from this.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:1 days, 03:58:29
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):11.7 dB / 25.0 dB
Line attenuation (Down/Up):19.5 dB / 7.5 dB
Output power (Down/Up):19.9 dBm / 12.3 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):19 / 4
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):31 / 0
Error Seconds (Local/Remote):366 / 39
Message 4 of 16
Re: New User Speed
like others on the forum with the same problem you need to stay connected 24/7 for 3/5 days and your profile should reset automatically.  once yo can show 3+ days connection and profile still at 2mb then contact the mods for assistance
contact mods
can take up to 3 working days for mods to contact you
But you need at least 3 days before contacting the mods
stuteman
Message 5 of 16
Re: New User Speed
Thanks, will do.
Message 6 of 16
Re: New User Speed
please keep us posted on progress
stuteman
Message 7 of 16
Re: New User Speed
Just noticed that Latency is set to Fast. I would have thought that would make the line more unstable so am not sure why it has been set that way.
NilSatisOptimum
Recognised Expert
Message 8 of 16
Re: New User Speed
Your right it can do, however you are reasonably close to the exchange. Its a automatic process, unless you have asked for interleaving to be switched off. Its good that your line can handle fast.
http://www.kitz.co.uk/adsl/interleaving.htm
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
stuteman
Message 9 of 16
Re: New User Speed
This is the 3 day result and I am still on 2 Meg. Will escalate to mods.
Best Effort Test:  -provides background information.
 Download  Speed
 1.79 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.79 Mbps
ADSL Line Status
Connection time:3 days, 00:27:13
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):11.6 dB / 25.0 dB
FEC Events (Down/Up):0 / 1
CRC Events (Down/Up):43 / 9
HEC Events (Down/Up):64 / 0
Error Seconds (Local/Remote):389 / 44
Message 10 of 16
Re: New User Speed
connection looks really good apart from the profile at 2mb  just contact the mods and then patience
