Jamie
Newbie
Message 1 of 3
New Wall Point
I currently have a wireless router downstairs for the internet but I was wondering how much it would cost to get a wall point in my bedroom for a wired router. I don't want a new number or new broadband plan, I just want a new wall point so I can have a wired router in my bedroom.
How much will this cost to have installed and how much monthly will this cost?
Thanks.
2 REPLIES 2
syops
Recognised Expert
Message 2 of 3
Re: New Wall Point
Do you mean you would like to use your current broadband connection in your bedroom as well as downstairs?
the simplest option would be to purchase a wireless adapter for the bedroom computer and connect to the wireless router.
Check your exchange or major service outages
If someone has given a helpful answer, please click on their Ratings star on the left-hand side. 🙂 ***
hamish72
Recognised Expert
Message 3 of 3
Re: New Wall Point
Sounds like you simply need an extension wired from down stairs phone socket to bedroom BT would charge about £200 (minimum call out £ 130) so  diy or get a local handy man to do it a lot cheaper
May sound silly but you do know only 1 adsl modem can be used per phone line ?
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
