Message 91 of 117
Re: New Yahoo e-mail screens
After you have managed to work it all out and have used it for a while please post back and let us know if you prefer it or if you miss your webmail with all its adverts and other problems.
Message 92 of 117
It may be called "get mail".
Message 93 of 117
It would appear that Thunderbird also checks automatically for email as well as allowing you to check manually.
Receiving messages
Thunderbird checks for new messages every time you open the application. It will also automatically check again every 10 minutes.
To check for messages at any other time, click the Get Messages button in the toolbar. get mail edit
Expert
Message 94 of 117
On my version, the latest, 31.6.0, it's called "Get Messages"
 Initial response to my feelings of Thunderbird, Yes it's better than BT Yahoo, not only no adverts, but the new BTYahoo package is a mess.
With the new BT Yahoo interface I can't find mails I've sent because they are locked to other mails.
Also some of my Contacts send me a mail but add it to a mail of another subject hence I get a mess that I'm finding hard to control.
Thunderbird is clean & simple.
Hope that helps some none users
Distinguished Guru
Distinguished Guru
Message 95 of 117
This manual might be a useful read.
Expert
Message 96 of 117
Thanks this could help
Expert
Message 97 of 117
From my point of view the worst part of the "upgrade" is how e mails are filed.
Replies to mails are blocked together as are additional mails that are sent in reply.
I'm now totally confused with this method.
Are others having the same problem?
And yes, I am getting used to Thunderbird
Message 98 of 117
Yes - I am having the same difficulty with regards to how the emails are lumped together.
Yes - I'm getting used to Thunderbird. I'm starting to use it more and more to overcome the problems with the layout of the new Bt Yahoo.
Message 99 of 117
If you are having problems with the new default email settings that list "conversations" you can turn it off by going into settings and deselect "enable converations"
Message 100 of 117
Thanks for the advice, just tried it and it works fine.
