Message 1 of 4
New bush TV won't connect to router
Hello.  I have just purchased a Bush Smart HD TV and I am unable to connect it to the internet.  I have strong Wifi signal.
I logged into the Smart Hub Manager.  The Bush TV is showing under "My devices" with following info:
Private IP 0.0.0.0 (Static)  Connection Status - Not connected
IPv6 addressing - this divide either does not support or is not configured for IPv6 addressing
Tried allocating manual static IP and auto, neither work, tried WPS, also doesnt work tho did work once for abt 2mins then dropped out.
Smartsetup is turned off on the hub
Ethernet not an option
Some advice would be appreciated please
Tags (3)
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: New bush TV won't connect to router
Login to your hub and Disable Smart Setup
Then do the network setup again choosing  Automatic (not static) addressing
Message 3 of 4
Hi I tried this it didn't work
Anonymous
Not applicable
Message 4 of 4
What's the IP address of the TV now according to the hub network manager ?
It should be in the range of 192.168.1.xxx
