D_L_
Message 1 of 35
New connection IP Profile stuck on 2MBs
My connection has been active for 10 days but is stuck with an IP profile on 2MBs.
 Download speedachieved during the test was - 2.19 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
I have taken all measures to irradicate any line problems and the ADSL stats on the Home Hub 4 show the following
Connection Information
Line state:Connected
Connection time:5 days, 20:04:29
Downstream:7.938 Mbps
Upstream:448 Kbps
I only live a few hundre metres from the exchange so I would expect at least 6MBs from this line.
How can I get this line retrained?
34 REPLIES 34
Message 2 of 35
Re: New connection IP Profile stuck on 2MBs
Your profile is stuck at 2mb and need mod help to fix it. When a mod reads your post i'm sure they will contact you
Moderator-Retired
Message 3 of 35
Hi D_L_,
Sorry about this, if you can fill out the contact us form in the about me section of my profile we can take a look for you.
Cheers
Chris
BT Mod Team
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
D_L_
Message 4 of 35
Do you mean the "send this user a private message"? The only contact us I can find is the default header one that is also at the top of this page?
Moderator-Retired
Message 5 of 35
Sorry D_L_,
I meant my actual profile, if you click my name there now, you should see the link.
Cheers,
Chris
BT Mod Team.
D_L_
Message 6 of 35
Form completed and sent
D_L_
Message 7 of 35
Hi,
Is there any way of finding out how long this will be before it can be fixed? It has been a week with no difference so far.
Message 8 of 35
the mods are very busy at the moment but normally the contact after around 6 working days
Moderator
Moderator
Message 9 of 35
Hi D_L_,
I have your email and I'll be in touch shortly.
Cheers
David
D_L_
Message 10 of 35
Hi David,
Do I need to restart my router at all? The connection is still on 2Mbs. I know you said it would fluctuate for a few days after but I thought there would be a change of some sort in a few hours while it starts learning again?
 Download speedachieved during the test was - 1.82 Mbps
