jonsmile
Message 1 of 11
New connection - only 33% of promised speed
So we signed up to infinity 2 and the checker says we should get min of 66meg and upto 80+meg.
Infinity installed and we were getting 30meg down and 16 up - but BT managed to kill my phone line - so called them - and they had me unplug router etc but not fix phone line
Now I get this speed.
1. Product Name: HomeHub5 2. Serial number: xxxxxxxxxxxxxxx 3. Firmware version: v0.07.03.0814-BT (Type B) Last updated [Unknown] 4. Board version: 01 5. VDSL uptime: 0 days, 00:59:23 6. Data Rate: 10565 / 22999 7. Maximum Data Rate: 10242 / 22977 8. Noise Margin: 5.6 / 5.8 9. Line Attenuation: 0.0 / 21.9 10. Signal Attenuation: 0.0 / 0.0
Any idea why is is so slow compared to promises?
10 REPLIES 10
Keith_Beddoe
Message 2 of 11
Re: New connection - only 33% of promised speed
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
jonsmile
Message 3 of 11
Hi
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 80 66.1 20 20 -- Available
FTTC Range B (Impacted) 80 57.1 20 17.9 -- Available
WBC ADSL 2+ Up to 17 -- 10 to 19.5 Available
ADSL Max Up to 7.5 -- 6.5 to 8 Available
WBC Fixed Rate 2 -- -- Available
Fixed Rate 2
Keith_Beddoe
Message 4 of 11
Could be a wiring issue in your house.
Connect things up as shown below, and see if the connection speed on the HH5 increases.
Is your phone working when things are connected up as shown?
Also make sure any extension that you have, are connected to the correct place as shown below.
john46
Message 5 of 11
Please use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If have a Homehub 5 can you also post the stats from 1-12 by logging onto the Homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
jonsmile
Message 6 of 11
Hi
Helpdesk details..
1. Product Name: HomeHub5 2. Serial number: xxxx 3. Firmware version: v0.07.03.0814-BT (Type B) Last updated [Unknown] 4. Board version: 01 5. VDSL uptime: 0 days, 13:47:28 6. Data Rate: 10565 / 22999 7. Maximum Data Rate: 11734 / 26340 8. Noise Margin: 6.7 / 7.0 9. Line Attenuation: 0.0 / 21.9 10. Signal Attenuation:
0.0 / 0.0
Test details.. fails (did not last night when the speed was 33/16)..
null
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
imjolly
Message 7 of 11
Do you have a dial tone from the test socket?  If not then that may well explain the low broadband speed as phone need both wires connected but broadband can work with one - but slowly
if no dial tone then phone 151 and report a phone fault
jonsmile
Message 8 of 11
I did have a dial tone from test socket and main line but when infinity 2 was installed, the phone line stopped working - so no dial tone and no possibility of calling 151 (also incoming calls do not ring on the phone). have logged this as a fault but bt say there is no fault on the line and it must be my issue - how can it be when I had a working phone before infinity 2 was installed? anyway engineer booked for tue and I have already said I will not pay the £129!
imjolly
Message 9 of 11
Is there no dial tone if you connect to the test socket now?
jonsmile
Message 10 of 11
Correct - now (post infinity) there is no dial tone
