Message 1 of 5
New customer - Home Hub 2 delivered without cables or filter
I moved into a new house and signed up to BT Broadband a week ago.  Just received my home hub 2 and it didn't have any means to plug it into the phone socket whatsoever. Is this normal?
They should have told me I would have to go source my own phone/broadband cables and filters at least.
4 REPLIES 4
Message 2 of 5
Re: New customer - Home Hub 2 delivered without cables or filter
is it a new build?   does it have FTTP - something like this
are you a new or existing customer
Message 3 of 5
Hi Thanks,
I'm a new customer. It's not a new build no.
This is what I got. No it doesn't have FTTP.
Message 4 of 5
you should have received a rj11 modem cable which connects hub to master socket and a filter in case needed   does your master socket have a separate outlet for adsl and one for phone?
you need to phone CS 150 or 0800800150 from mobile
Message 5 of 5
Have contacted them on that number and they're sending out a cable and filter. The master socket only has one output so will need a filter.
Turns out it was a mix up with them thinking I had existing hardware.
Thanks for your help.
