Message 61 of 120
Re: New customer - tearing hair out with disconnects!
I got wifi analyzer and there's definitely tons of other stuff, but I'm now on Channel 13 for 2g whcih is clear at the top with only one other overlap on Band 11
There's more interference on the 5G with someone elses BT being stronger than mine (oddly... it has an X on the end so must be special). But the 5g on the BT is fine (5G on the other not, but maybe clashing with the BT wifi i guess...?!)
Message 62 of 120
It will be BT WiFi X, coming from your own home hub, if you are using it. If you alter the 5G channel, it will follow.
Message 63 of 120
Okay, well that explains why I get stronger signal from 5G BT. And maybe explains why my 5G from Other router might have interferences...
Doesnt explain why my 2g from either device keeps dropping tho...
Message 64 of 120
I've shifted my BT Hub 5g down to band 36, but doesnt seem to make any difference - still spanning bands 34-50... can you change the width at all?
What do the wifi modes do?
Message 65 of 120
For the next step I would replace the Hub with the Openreach modem/Archer combination and see if that is stable.
Message 66 of 120
Yeah, i think that needs to be the next step. I've disabled the wifi on the BT router, and was still getting disconnects from the Archer, so can rule out any kind of internal conflict...
And now, re-enabled and am getting disconnects from the BT 5g too 😞
Message 67 of 120
Just enabled DHCP on my archer and plugged in Modem. Connected modem to internet port on router (direct)
I'm getting nothing in the way of internet tho - am I missing something?
Message 68 of 120
Can't see how to edit on my mobile, but just wanted to add that all three lights on modem are green and I've also tried a reset
Message 69 of 120
You need to enter bthomehub@btbroadband.com as the user name and BT for password in the Archer PPPoE setup.
Message 70 of 120
Ah ha - thanks - i actually just found a slightly different combo from another thread that seemed to work...
Bad news... same issue.
2g is disconnecting frequently 😞 (even sitting right next to the router...)
17/11/2017 12:56:28 Log Start
Failure Start Length
17/11/2017 12:57:15 0:00:08
17/11/2017 12:57:51 0:00:07
17/11/2017 12:58:10 0:00:41
17/11/2017 12:59:03
Same thing with 5g it seems 😞
17/11/2017 12:59:56 Log Start
17/11/2017 13:00:19 0:00:14
17/11/2017 13:00:46 0:00:14
17/11/2017 13:01:15 0:00:52
So I have no idea where to go from here...
I've seen the same issue with
- the same setup I had previously
- Home plugs in place
- Home plugs not in place
- ONLY the BT hub.
- BT Modem and Archer C9
Anyone?!
