Message 101 of 120
Re: New customer - tearing hair out with disconnects!
@licquorice wrote:
If the problem occurs on multiple devices and both routers the only conclusion I can draw is that it is the environment.
A bit drastic, but can you try the Archer at another location with your laptop and ideally another laptop.
I don't understand how the environment can suddenly have changed with the introduction of BT, but I can't see what else it can be given the prevelence on all devices...
Message 102 of 120
@pippincp wrote:
@vaderag wrote:
@pippincp wrote:
@vaderag wrote:
@licquorice wrote:
Don't forget to disable the inbuilt wifi adaptor Smiley Wink
Spoke too soon - too old to even find drivers for it... pre windows 7!
Use Vista or XP drivers. Windows 7 is Vista with XP under the hood with a bit of tweaking added.
I'm on Windows 10. It doesnt work
Post the make and model and I'll have a look for you.
US Robotics USR805422
Message 103 of 120
When you tried it with the Archer and Openreach modem only, did you completely de-power the Hub and extenders. Just wondering if their PSUs are the cause of any interference.
Message 104 of 120
Hub, yes. Powerline's, no (but they were in place in the old setup)
Sage
Message 105 of 120
Try this one. Most likely an XP one so if necessary run in compatability mode.
Message 106 of 120
I tried it - windows wouldnt even recognize the driver, and installing gives you some wierd app that didn't work even in compatibility
Sage
Message 107 of 120
Strange, I've just gone through the install process as far as having to plug in the adaptor with no problem on a windows 10 laptop. Obviously I can't go further as I don't have an adapter.
You didn't by any chance download the archived driver rather than the XP win 2K driver did you?
Message 108 of 120
Not sure. The install works fine, you end up with the system tray icon but it doesn't do anything once device plugged in and shows as broken in device manager.
Sage
Message 109 of 120
Not having one myself I can't offer further help with it.
Message 110 of 120
That's fine, it's not really the issue anyway, I've tried many devices but they are all suffering same issue 😞
