Message 1 of 29
New customer
Hi to all,
I just came back to BT last week, engineer fitted new drop line, wiring and master socket
I told the engineer that I had a lot off issues in the past and had found that 21cn on 992.3 (adsl2) with interleaving had been found to work the best with speed and reliability.
however, despite the info, he connected me on ADSL Max as per BT standard protocol for longer lines,which peeved me off as I had only just came back.
now here I am with a 9.5 snr on fast path with a much slower sync.
The router had been left alone, I reset it an hour ago (waited 30 minutes) hoping the snr would pull back down to 6 and turn on interleaving, but it has stayed where it is.
I am afraid now that because of new line training, that the Dom has decided this is the best it can do, which is incorrect.
I am happy enough to give g.dmt a chance to see how it fairs this time, I was just hoping to request a MOD to reset line back to 6 SNR and apply the interleaving.
Hopefully the training period with interleaving applied the snr will stay there, but of not can go back to my test and tried setup as before.
28 REPLIES 28
Message 2 of 29
Re: New customer
13:54
. 4G
192.168.1.254
BT Smart Hub Manager
Technical log
Information
Event log
Data rate:  448 kbps / 2.69 Mbps
Maximum data rate:  1236 / 2912
Noise margin:  24 db / 9.6 db
Line attenuation:  54 db
Signal attenuation:  31.5 db /  54 db
Modulation:  G_992_1_ANNEX_A
Fast Path
Message 3 of 29
Re: New customer
From your stats the max down  speed is only 2.9mb so unlikely much change even if adsl2. Up speed would be far better on adsl2
enter phone number and post results  delete number but leave exchange and cab
Message 4 of 29
Re: New customer
Thanks for the reply,
I think that’s dlm has kicking in giving that as a max, when it first connected the at 6snr, the max was 3600, a few days ago it changed  to that figure
Message 5 of 29
Re: New customer
Also, just to note, I always get a sync of around 3500 before, even 4 in the summer
Message 6 of 29
Re: New customer
I’m assuming that max rate is based on the current snr of 10
Message 7 of 29
Re: New customer
The max data rate is best your line can do.  The higher noise margin is due to your connection speed being below thee attainable rate
just run dslchecker so we can see what is available to you save the guessing
Message 8 of 29
Re: New customer
Thanks for response again, the wholesale check is saying Adsl max 1- 2.5 and Adsl2+ 1 -  3.5, so it is obviously openreach putting me on max that has slowed things down.
the 21cn previously I had must just perform better.
in that case, since I had actually requested 21cn from the start, maybe the mods could arrange a switchover for me.
Message 9 of 29
Re: New customer
Just to note, it does seem rather odd that my neighbour next door, with their line running off the same pole has a current sync of 4.6, when I checked they are on adsl max as well.
openreach fitted whole new line to my house too, so can’t be any errors that side and have no extensions or anything in house either, drop wire straight to the master.
I find it hard to understand how the house next door to me has nearly twice the speed
Message 10 of 29
Re: New customer
please can you post full dslchecker results  you can use camera icon
Try phoning CS on 150 and see if you can get them to help you move to adsl2. Probably not much change to down speed but certainly faster up speed
no 2 lines are the same so your neighbour could have a better line than you all the way back to the exchange
