Dg2k187
Message 271 of 325
Re: New firmware kills VPN
I am also unable to use VPN connections with HomeHub 3.0.
Please can you also invite me so I am able to email you my details, then you can update my firmware?
Dg2k187
Message 272 of 325
To confirm I am currently using the BT-WiFi connection as a workaround for this issue.
Dg2k187
Message 273 of 325
* UPDATE *
The BT-WiFi connection workaround caused some complications & my device to malfunction.. Smiley Mad so I have reverted back to my Ethernet Wired Connection & I will wait for assistance & further instructions.. Smiley Sad
Moderator
Moderator
Message 274 of 325
Hi Dg2k187,
Please use the 'contact the mods' link in my forum profile under the 'about me' section to send in your details remember to include your Hub serial number. You can find the link by clicking on my username.
Cheers
Neil
Robbies21
Message 275 of 325
I have had the issue within this thread and recently requested that I am sent Home Hub 5 to resolve the VPN issues I am having with home hub 3, so my question now is, will I still have the same issue with home hub 5 at all please?
stevie_p
Message 276 of 325
Hi Neil,
I am also affected by this issue (HH3), but I don't see a 'contact the mods' link when going into your profile?
Thanks,
Steve
Moderator
Moderator
Message 277 of 325
Hi stevie_p,
Welcome to the forum, the link is only available after an invite by one of the mods, if you click on my profile you should be able to see it now. Please ensure to include your hub serial number.
Neil
stevie_p
Message 278 of 325
Thanks Neil,
Got it now.
Regards,
Steve
Robbies21
Message 279 of 325
Neil,
Can I have an answer to my question above please?
Rob.
Community Manager
Community Manager
Message 280 of 325
Hi Robbie,
Thanks for the post and welcome to the forum.
Th problem highlighted on this thread is just related to the BT Home hub 3.0A as there was a firmware that was released which caused the problem.  We don't believe there is an issue with accessing VPN using any other Home hub including the Hub 5.
Cheers
Sean
