FionaWaugh
Message 301 of 325
Re: New firmware kills VPN
Hi,
I'm using a HomeHub 3 and am unable to connect to VPN.  Can you send me the VPN firmware fix please?
Fiona
stevie_p
Message 302 of 325
Hi Neil/Craig,
Just to say that my router's firmware has been upgraded, and that it's now running fine again - many thanks for the prompt response!
Regards,
Steve
Community Manager
Community Manager
Message 303 of 325
Hi Guys,
Robbies21 – We have added your name to the list and you will have the update pushed within the next 24-48 hours.
Dg2k187 – Your details have been added as well.
Stevie_P – thanks for the confirmation and sorry for the confusion caused.
FionaWaugh – Welcome to the forum.  Please could you drop me an email.  I will need the telephone number your broadband is active on as well as the serial number on your hub.  Click on my username (SeanD) and you will find the ‘Mod Contact link’ under the about me section of my profile.  Once we receive your details we will add to the list and the update will be pushed to your hub.
Cheers
Sean
Robbies21
Message 304 of 325
Thank you Sean.
Damo86
Message 305 of 325
Maybe It's not only VPN but also port forwarding and DDNS setup not doing anything. I wonder if they test their hubs firmware before they roll it out.
I have asked BT about this and all I got is a voice mail telling me 'I had to pay for that support' when all I wanted was help with my hub.
My solution: bought a new router which worked straight out of the box, bang.
bparsons1984
Message 306 of 325
Just want to say thank you, the Firmware update resolved the issue with my clients equipment.
Cheers,
Ben
Robbies21
Message 307 of 325
Damo86, Has there been other updates as well as the firmware within your environment within the last two weeks?
hazelhaynes
Message 308 of 325
Sean, I've just sent my info across also, can I be added to this push update? Thanks
Moderator
Moderator
Message 309 of 325
Hi hazelhaynes,
Welcome to the forum and thanks for posting.  I've checked and your details are not in our queue, if you've PM'd Sean may I ask that you use the contact the mods link instead? The link can be found by clicking on my username.
Cheers
Neil
Arul
Message 310 of 325
Hi Mod,
Thank you very much !! I have got my firmware updated and VPN is working successfully again.
Thanks,
Arul
