nozza101
Message 1 of 5
New home hub (6)
Hi I'm getting a bt infinity installed on Friday and it says I will get new home hub. Can I use my old Linksys wrt1900acs along side it ?
4 REPLIES 4
licquorice
Message 2 of 5
Re: New home hub (6)
What modem are you currently using with the Linksys? The hub doesn't have a modem only mode, if your current modem has vdsl capability, continue to use that. You can connect the Linksys to the hub, but it will just be an expensive wap
nozza101
Message 3 of 5
Hi , thanks for the reply . Currently I'm with virgin so using superhub in modern mode .
Craig
licquorice
Message 4 of 5
Ah, might be worth investing in an Openreach hg612 modem from the well known auction site then.
nozza101
Message 5 of 5
Thanks pal
