studleymax
Message 1 of 84
New problem since VLAN issue resolved at the exchange previously after action via Mod on this site
Hi All,
I now have another problem on my BT infinity line. I had originally had a line speed issue, whereby it would connect at 42mbps, but I was only getting 1 -2 mb download speed. This was eventually sorted out when a Mod on this forum stepped in and helped me out. It turned out to be VLAN issue at the Exchange.
My new problem is this:
Issues with crackling and hiss on phone line, so unplug phone and BT Hub 5, then replug/reboot BT Hub 5. Crackling goes away on phone line, and reouter connects at 42mbps. So all good. Then about 4 -5 hours in, suddendly the crackling/hiss on the phone returns and the router has dropped connection, then reconnected at, say, 30mbps. I contacted BT and decided to agree to Open Reach engineer visiting my house to check the line. He did this yesterday, plugged his test equipment in and found no problem. Whilst he was there he did replace the master socket, as I had quite an old one. I did express concern to him about whether I would be charged £130 for the visit, and he was quite vague about this... So hopefully not!
Anyway I decided to run a soak test overnight with RouterStatsHub v1.7.0 and this is what it showed:
So it would appear that the behaviour manifests itself after a period of connection without issues. So when Open Reach engineer tested (he plugged in his equipment) it started a fresh connection, and all was well. I'm not sure where to go with this as I will end up in the same loop if I call BT again...
Note that I tried using the test port on the socket previously, and experienced the same issues....
Note also that I do not have any other sockets connections in the entire house, just the one master socket...
83 REPLIES 83
licquorice
Message 2 of 84
Re: New problem since WLAN issue resolved at the exchange previously after action via Mod on this si
There is definitely a fault on your line if you can hear noise. If the SNRM graph looks like that when connected to the test socket behind the removable faceplate of the master socket, the problem is outside of your property and the responsibility of Openreach. Unfortunately, it can be very difficult to track down the source of intermittent faults.
studleymax
Message 3 of 84
Apologies - Can one of the mods delete this post - I have somehow managed to post twice!!!
Keith_Beddoe
Message 4 of 84
Is that correct now?
I think you mean VLAN, not WLAN.
studleymax
Message 5 of 84
Re: New problem since VLAN issue resolved at the exchange previously after action via Mod on this si
This post is my original post, I have asked for my erroneous post to be deleted...
Keith_Beddoe
Message 6 of 84
I have moved the replies here. Hopefully that is what you wanted. @licquorice thinks you may have a line fault.
studleymax
Message 7 of 84
Yes, this is the post I wanted to keep! Thanks.
studleymax
Message 8 of 84
So how best do I go about addressing this problem with BT?
john46
Message 9 of 84
report a noisy phone line on 151 with no mention of broadband in the call
studleymax
Message 10 of 84
Just tried the suggestion of phoning them with a line fauly. Guess what - they want to send an Open Reach engineer round to test the equipment!!!
Problem manifests itself 5 hours after initial plug in...
Going round in circles...
