Message 1 of 3
New setup cables
Hi there, I'm getting Infinity 1 next week, but due to the (unchangeable) layout of the room, my phone socket is in one corner, and the PC is in the opposite corner, so to connect my PC to the hub I'd need either a 10m telephone extension cable, or a 10m cat 5e ethernet extension cable.
Can anyone advise me please as to which is the best, in terms of speed etc?
Thanks..
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: New setup cables
Use the ethernet as telephone extensions are know to cause problems with connections
Message 3 of 3
Many thanks for the advice, much appreciated.
