somhairle
Message 1 of 45
New to BT Infinity But Disappointed
I moved to BT Infinity yesterday from standard BT Broadband and was given an indication that my speeds would be 32-43mb down and 6-8mb up. So far the speeds have been nothing close to this and are only slightly better than standard speeds. I used to get around 16/17mb speeds and now I am getting at best 21mb. This has improved slightly on the initial speed of 19mb but is still miles off what I was led to expect.
I know which switching service provider some tweaking can take place over the first few days, but not sure that happens with Infinity as I have not noticed any change to my IP since it was started.
Soooo....... Is it likely that this is what I can expect as a standard from Infinity or is there hope for the future?
For what it is worth, I am around 1km from the exchange and half that from the green box.
44 REPLIES 44
Webby
Message 2 of 45
Re: New to BT Infinity But Disappointed
Can you post the connection stats from the router?
Are you testing wirelessly or with a wired connection?
pippincp
Message 3 of 45
To get the stats: Openi a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
somhairle
Message 4 of 45
Here you go:
Product name:
BT Hub 6A
Serial number:
+084319+NQ72421980
Firmware version:
SG4B1000B316
Firmware updated:
17-Sep-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 20 Hours 2 Minutes 15 Seconds
Data rate:
4.47 Mbps / 21.54 Mbps
Maximum data rate:
4466 / 22135
Noise margin:
5.9 dB / 6.5 dB
Line attenuation:
30.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
16493 MB Uploaded / 22007 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-CFGZ
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-CFGZ
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
B8:EE:0E:B3:13:7D
Software variant:
Boot loader:
7.33.1
Webby
Message 5 of 45
Can you put your number into here https://www.dslchecker.bt.com and post a screenshot of the results.
Is your router connected to the master socket? Or an extension?
somhairle
Message 6 of 45
The router is connected to the master socket - NTE2000 type.
Here is the screen shot you required.
Webby
Message 7 of 45
Can you remove the faceplate and connect to the test socket?
This will remove all internal wiring.
somhairle
Message 8 of 45
Virtually the same result - 21.57/4.48.
Does anything in the information that has been requested indicate any problem?
pippincp
Message 9 of 45
Has the max data rate changed while connected to the test socket?
Webby
Message 10 of 45
If it hasn’t, you need an engineer visit.
