athegn
Message 1 of 8
New to BT Mobile but not BT and roaming
I have had Bt Broadband for many years but have only just got BT mobile Pay monthly account and am wondering about Euro roaming.
I read that you need 6 months credit history before roaming us allowed. Does that also apply to someone with a long hIstory of BT broadband?
Secondly, assuming I can have roaming, does it work like my previous 02 roaming, where I had to do nothing but just connect to the local 02 provider and use the data but pay £1.99 per day.
I think that BT is more expensive at £3.99 per day.
Any advice please?
7 REPLIES 7
PaddyB
Moderator
Moderator
Message 2 of 8
Re: New to BT Mobile but not BT and roaming
Hi @athegn,
If you have had BT Broadband for awhile then you should be able to add Roaming without any issues.
If you take a look at BT Mobile: What do I need to do before I go abroad?, you'll find a few details about using the service.
PaddyB
athegn
Message 3 of 8
I tried your link but got "unexpected error"
RobbieMac
Moderator
Moderator
Message 4 of 8
Whoops @athegn
Try this link here - BT Mobile: What do I need to do before I go abroad?
Apologies for the mix up.
Cheers,
Robbie
athegn
Message 5 of 8
Looking at your link and APN I see I have two BT APN; but both are BT Internet not BT Mobile. Both seem to have the same settings; same with two BT MMS not plain MMS. Note radio button checked on second BT Internet
Should I create BT Mobile and MMS APN?
DanielS
Moderator
Moderator
Message 6 of 8
Hi @athegn,
If you are comfortable creating it then yes please.
It's best to the settings outlined in BT Mobile: What do I need to do before I go abroad?
DanielS
athegn
Message 7 of 8
Don't know if I am comfortable with it, but just created an APN for my HTC Desire for its Orange supplier and mobile data now works; not tried that phone abroad though!
Will give it a go.
athegn
Message 8 of 8
Set up two new APNs.
When I set up the Orange APN I was offered an option of * for APN type only if tapping on field brought up the keyboard.
The BT setting do not offer a guide on whether to choose MMS or *; I choose MMS. Is this correct?
