Blisteringblue
Message 1 of 7
New to Infinity, but want to keep Openreach Modem and Draytek 2830n
Hi All,
Been with plusnet for ages and have their 76mb Fibre working perfectly with Openreach Modem and A Draytek Vigor 2830n router.
Just signed up to Infinity 1 because the deal was too good to miss to get Bt Sport Europe, but I don't want to use the HH5 that is winging its way to me.  And yes I know Infinity 1 is only 38mb, but it was a tenner.
Am I right in the thinking the current setup will still be working after my switch over.   I only need to swap my PPoE username to be "bthomehub@btbroadband.com" with a blank password?
I also have the router settings to make the multicast work too.
6 REPLIES 6
imjolly
Message 2 of 7
Re: New to Infinity, but want to keep Openreach Modem and Draytek 2830n
yes that should work ok
gg30340
Message 3 of 7
You may need to enter a password, if you do just use anything you like.
Blisteringblue
Message 4 of 7
Thanks for the replies, that is good to know.
I know if things don't work can always plug the HH5 in.
Blisteringblue
Message 5 of 7
Just to say, swapped over this morning, happy to report all working fine with the Draytek, including all the TV.   Had a bit of fiddling with some odd settings to do with Multi-PVC but as soon as I disabled it everything sprung into life.  So HH5 can happily sit in it's wrapping.
Decent speed too 37.4mb for infinity 1, but I am across the road from the green box Smiley Very Happy
http://www.speedtest.net/my-result/4578813077
Happy Days, all ready for the Champions League now.
pippincp
Message 6 of 7
By far the best option.
ISP routers are all cheap carp.
Blisteringblue
Message 7 of 7
I know, work provided the Draytek and it's a superb bit of kit. Plus we subscribe to OpenDNS to stop the kids getting to places they shouldn't and I always wondered if BT would prevent you changing your DNS with the HH? I know Sky used to back in the day, had to "hack" their firmware to change the DNS.
Anyway, Happy Happy Days
