Hi,
Upgraded to Infinity 1 on the 52mb package a few weeks ago and was told this is the speed I would get. However after letting the service run for the 10 days I was still only in the high 20s. It did start to climb but stuck in the mid 30s. A BT engineer came out (not sure what he did) and now I'm at 39mb and he told us the best we would get was 40mb. Not vey happy as this is not what I was told when I signed up, i could have got better deals with other providers for basically the same speed but the 52mb swung me. What I don't understand is using the ADSL checker it shows below. If it is the case we can get what it says why did the engineer tell us we would only get 40mb on the 52mb service? I would even consider changing to Infinity 2 if I could get the higher speed and make BT refund the £50 activation fee and pay the extra monthly as it is a minimal difference over the term of the contract. Considering the false statements given to me when getting Infinity 1 I don't trust what I might get told. Am I missing something here?
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
are you connected to test socket with a new filter especially if you have extension sockets in other rooms
was the dslchecker based on your phone number
try quiet line test dial 17070 option 2 should be quiet and best with corded phone
I wasn't there when the engineer visited and he didn't elaborate why 40mb was the max to my wife. Looking back at the email confirmation it states a guaranteed minimum of 50mb.
I will get the info tonight from the HH5.
I am currently connected to the faceplate although have tried through the test socket and got the same results. I'm reluctante to plug back into the test socket as i don't want to disconnect again and I got not difference before. I don't have any extensions connected or wired into the socket. The filter is new as i used the one that came with the home hub. Dslchecker was based on my phone number.
I also tried the quiet line test after reading your other help posts and while I don't have a wired phone I couldn't hear any noise on the line.
Here is the info from the HH5. The low uptime is because it rebooted last night
Thanks for looking, what causes a high attenuation and what does it effect?
I have no idea where the cabinet is, are they always overground or could it be underground?
