Message 1 of 12
New user - Wifi weak 6 foot from SH2
Hi,
I join BT on Thursday and thought all was good. Tonight I'm having issues with my WIFI. I'm sat about 6ft from the hub but when tested it reports weak signal
Also I know the speed will take 10 days to settle, but my tests today have been shocking.
 Any help appreciated.
11 REPLIES 11
Message 2 of 12
Re: New user - Wifi weak 6 foot from SH2
Ps my speed is 150mb .. guaranteed to be 100mb.
Message 3 of 12
Dud you turn off smart setup in hub settings?
did you try selecting channels manually instead of automatic
Message 4 of 12
Hi @london238 ,
Welcome to the Community!
Sorry to hear about your issue.
Do you have any other devices to test this on? Is it only on this device?
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Message 5 of 12
Hi,
Have checked with my tablet, that is strong but my mobile is weak. All are connected at 5GHz. Note9 is connected at 780Mbps but is weak. Tab-A is connected at 6 Mbps is strong. Both tested from the same spot.
Message 6 of 12
Did you turn off smart setup
Message 7 of 12
Install Aruba Utilities on your Android device. Open it, let it scan for a few minutes, then post a screenshot here, please.
Message 8 of 12
Smartscan disabled and channels set manually. Same results on the 2 devices.
Message 9 of 12
Hi, have downloaded Aruba utils to my phone, will test when I get home.
Anonymous
Not applicable
Message 10 of 12
Try making your phone re-aquire the wi-fi by putting it in airplane mode for about 30 seconds
