Message 1 of 4
Newbie- No aerial only want BT Sport on youview.
Hi folks,
Im getting Infinity Activated on Mon. I ordered Infinity and BT TV with the free BT sport.
I recieved my router and you view box today.
Its all hooked up but ive no aerial so obviously recieve no chanels.
Q- Once i recieve my Broadband will i recieve BT sport? ( through broadband )
I dont care about freeview, only want bt sport.
OR will i need an aerial into it as well for some reason?
3 REPLIES 3
Message 2 of 4
Re: Newbie- No aerial only want BT Sport on youview.
Would expect the internet channels inc BT Sport to work OK with or without an aerial - cant imagine any technical limitations that would obstruct this.
You will also of course get the full Youview terrestrial on demand offering including the BBC Iplayer which is best version I've seen.
Distinguished Guru
Message 3 of 4
But it might need an aerial to do the initial set up and to update the software
toekneem
(EASBF)
Message 4 of 4
it should still setup without an aerial, if not an old coat hanger should do the trick and if it finds any freeview channels just hide them 🙂
