Mistypat
Newbie
Message 1 of 2
Newcomer has worldwide BT wifi question
I am a newcomer to BT WiFi. I have installed the BT wifi app on my IPad. I am shortly visiting Venice, Italy, does this mean I can connect using WiFi while there. Thank you.
1 REPLY 1
Message 2 of 2
Re: Newcomer has worldwide BT wifi question
Welcome.
Provided you check your opt in status as 'in' before you go in good time, and you can find a partner site - yes.
The Fon website has a map with partner sites, but dont trust the geographic accuracy of the map too much.
AQ.
"Welcome to Royston Vasey - You'll never leave."
