pm
Message 1 of 5
No ADSL link after moving home
Dear Moderators,
I moved home within E14 area. I had a working internet connection despite issues being posted around Poplar area and the 02075 issue.
After moving house, the same number issued, but I checked the hub and there is no ADSL link at all.
I double checked to make sure nothing else is connected, ensured only the BT home hub was connected, there is neither a blue or yellow light and finally changed filters. I logged inside the BT home hub and the hub says no ADSL connection
I called the help desk who did the line test and I explained what I did and they asked me to change filters again, reboot router, reboot my computer. It was promoted to 2nd line and I was told I would be contacted in 5 hours, I have waited the whole day at home.
Any chance someone could check on the exchange what the issue is and see if there is a ADSL link and whether it is ADSL 2+? If you can provide an email address, I can email you my BT number.
Thanks.
4 REPLIES 4
Message 2 of 5
Re: No ADSL link after moving home
email the mods  http://bt.custhelp.com/app/contact_email/c/4951
can take 2/3 days for mods to reply
pm
Message 3 of 5
Thank you 🙂
pm
Message 4 of 5
Thanks for your help mods. Very professional help and the personal touch of calling me to keep me updated was very nice.
Lastly, I was told my line supported ADSL2, however when my ADSL came online it only shows 2MB/s (my estimated speed was 7MB/s), can someone please take a look?
Connection information
Line stateConnected
Connection time0 days, 0:40:58
Downstream2,563 Kbps
Upstream967 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.3
Latency typeInterleaved
Noise margin (Down/Up)5.9 dB / 6.5 dB
Line attenuation (Down/Up)51.0 dB / 31.3 dB
Output power (Down/Up)0.0 dBm / 12.9 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)205 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)92
Message 5 of 5
you are on adsl2
as you line has just started then you are in a 10 day training period where you need to stay connected 24/7.  during this period the router may reset a few time while the exchnage tries to find the best stable speed for your line.
after that period then post stats again if still need more assistance
