Message 1 of 8
No BT sport ultimate on 2021 Amazon Firestick 4k
I have just recently purchased this Firestick and downloaded the BT sports app. I get ultimate via my subscription normally but wanted to be able to watch in a back room without constantly moving my box. I have logged into my app and I get all the sports channels in HD but the ultimate channel is not listed. I have checked the device compatibility on my Firestick and all options are ticked as working. My output resolution is set at 2160. Any ideas please?
7 REPLIES 7
Message 2 of 8
Re: No BT sport ultimate on 2021 Amazon Firestick 4k
Is this even when a live event is on the channel? I seem to remember the ultimate option only appears in the app when there's a live event on
Message 3 of 8
Well this is possible and there is a match this afternoon so I was going to check that then but thanks for your reply
Message 4 of 8
@Reggie1952
the Celtic game this afternoon is only one today that shows 'ultimate'
Message 5 of 8
You'll be offered Ultimate when an event is on it. If you launch the app after the event has started then it'll be the first thing you see. If you're already watching the relevant HD channel when the Ultimate event starts, you'll see a prompt on screen saying it's now available on Ultimate.
e.g. this afternoon's Ultimate event starts at 3pm (for a 3:30pm kick off). If you're watching BT Sport 1 before 3pm, you'll see a prompt to switch to Ultimate. If you launch the app after 3pm, it'll show the link to Ultimate at the top of the first screen.
Message 6 of 8
Sounds logical now you have explained this. I will try this later today and reply back here with an update. Thanks
Message 7 of 8
Spot on as you mentioned thanks
Message 8 of 8
You were correct thanks
