Rhaego
Message 11 of 28
Re: No Broadband Connection - Flashing Pink Light of Doom
Well, it looks connected to me.
john46
Message 12 of 28
if your hub was connected you would show a blue light continuously on the hub not a flashing pink one
Rhaego
Message 13 of 28
Cable I mean,
i guess I just have to wait for the new router.
XRaySpeX
Recognised Expert
Message 14 of 28
Eh? I thought you knew it wasn't activated from your OP.
Yes, a cable connected to no signal.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Rhaego
Message 15 of 28
Yeah sorry. But of misunderstanding.
BT seem to think it is activated. There's nothing more I can do to convince them otherwise.
XRaySpeX
Recognised Expert
Message 16 of 28
This will need a mod to to take it on further if the replacement router doesn't fix it.
Rhaego
Message 17 of 28
Thanks for your input.
I will report back when I get my replacement hub. Fingers crossed.
Rhaego
Message 18 of 28
So an update...
my broadband and returned randomly on Monday afternoon. This was before my new hub arrived. Again it worked like it never went off until Friday afternoon. 2nd weekend where I don’t have a broadband connection and it’s the same issue. No one is able to give me a clear answer.
The light on on my router is now a solid orange rather than flashing purple.
ive spoken to BT again and they have logged a fault. I was supposed to be contacted by an engineer but no one has called.
I would like like a mod to comment ideally. I have checked my line, checked my local area for known faults and even tried my new hub. This is becoming increasingly frustrating and I am fractions away from cancelling when my contract ends next month.
ill repeat - a mod comment would be appreciated
DavidM
Moderator
Moderator
Message 19 of 28
Hi @Rhaego and thanks for posting.
I'm sorry you're having so many problems with your connection. I'm sure I can help you with this. Can you please drop me over an email with your details. You'll get the contact the moderators link in my profile. We're very busy at present so it's taking longer than expected to reply but once you submit the details we'll get to you in turn.
Cheers
David
Rhaego
Message 20 of 28
Submitted. Thanks
