Message 11 of 49
Re: No Broadband connection
just need to keep checking but hopefully stats will be fine
watching your grandson play football is a lot more important and enjoyable than resetting your hubSmiley Happy
Expert
Message 12 of 49
Morning imjolly,
I lost my broadband connection again some time between 07:45 and 08:15.  I tried a restart but that had did not bring it back.  Left it for a while and did a factory reset at about 08:40.  That re-established a connect but again it is slow and there are are lot of errors, viz :-
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:0 days, 00:17:38
Downstream:2.491 Mbps
Upstream:803.4 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):5.1 dB / 6.3 dB
Line attenuation (Down/Up):57.6 dB / 33.7 dB
Output power (Down/Up):17.2 dBm / 12.6 dBm
FEC Events (Down/Up):89210 / 30
CRC Events (Down/Up):172 / 32
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1224 / 8
Error Seconds (Local/Remote):8 / 0
Have you any idea what should be causing this please ?
I will wait to hear from you before ringing BT again.
Best regards,
dfenceman
Message 13 of 49
did you try quiet line test?
Expert
Message 14 of 49
Yes, several times, silent every time
Best regards,
dfenceman
Expert
Message 15 of 49
Hi imjolly,
I tried online chat but whoever was at the other end could not access my fault.  She said she would raise the issue with a colleague and they would ring back with an update within 20 minutes.  Surprise no call back.
Have tried emailing BT and had the following various responses between 12:29 & 13:35 :-
1. If this issue is not resolved to your satisfaction, you may reopen it within the next 0 days.
2. Thanks for contacting us, we will reply to you as soon as we can.
3. Thanks for contacting us, we will reply to you as soon as we can.
4. Our aim is to get back to you in 24 hrs. But at busier times, it could take us up to 72 hrs. Either way, don't worry we'll be in touch
5. Your question has been received. You should expect a response from us within 24 hours.
6. Thanks for contacting us, we will reply to you as soon as we can.
I wonder who will be the first to respond and when ?
Best regards,
dfenceman
Expert
Message 16 of 49
Hi imjolly,
BT Line Faults were the first to respond with an email as follows, at 15:55 :-
Hi xxxxxx i received your email regarding the broadband issue and i call you today however there is no response from your end so i am going to give you the call back again on tomorrow between 16:00-18:00 PM
If you will receive the call then it will be easy for me to get the issue resolve for you.
Complain No- VOL012-10574468xxxx
Best regards,
dfenceman
Expert
Message 17 of 49
Good morning imjolly,
Things are clearly still not right.  Look at the CRC & HEC events.  What do you think is causing them please ?
ADSL Line Status
Connection time:0 days, 21:55:51
Upstream:803.4 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.5 dB / 5.7 dB
FEC Events (Down/Up):12835373 / 7856
CRC Events (Down/Up):40912 / 184
HEC Events (Down/Up):848251 / 442
Error Seconds (Local/Remote):807 / 68
Best regards,
dfenceman
Message 18 of 49
usual cause is line noise or interference   looks like back to old days
Expert
Message 19 of 49
Hi imjolly,
I wonder if it was noise or interference that caused the fault ?
I restarted the hub at your recommended midday and speeds are back up.  Errors look OK but I have been out and only just got back to run the stats.
ADSL Line Status
Connection time:0 days, 04:10:26
Downstream:2.835 Mbps
Upstream:776 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:Unknown or no mode configured
Noise margin (Down/Up):6.2 dB / 6.0 dB
Line attenuation (Down/Up):56.1 dB / 33.7 dB
Output power (Down/Up):17.4 dBm / 12.5 dBm
FEC Events (Down/Up):2538 / 1472
CRC Events (Down/Up):6 / 47
HEC Events (Down/Up):48 / 41
Error Seconds (Local/Remote):4 / 8
I'm due that call from BT between 16:00 & 18:00.  I'll see what they have to say.
Best regards,
dfenceman
Message 20 of 49
looking better hopefully if you do get a call they do not reset your connection
