Expert
Message 21 of 49
Re: No Broadband connection
Hi imjolly,
I had the promised call and within the 2 hour window.
However, he offered no explanation as to waht the fault was and exactly when it was fixed.
He is going to ring back again tomorrow.  Not sure quite why, other than I said I wanted to know how he proposes to pay my travelling expenses for returning to the property last Friday on the promise that the fault was fixed when it wasn't.
Best regards,
dfenceman
Expert
Message 22 of 49
Morning imjolly,
Well the errors are OK this morning but the noise margin is down to 1.9dB, viz :-
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:0 days, 18:19:06
Downstream:2.835 Mbps
Upstream:776 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):1.9 dB / 7.1 dB
Line attenuation (Down/Up):56.1 dB / 33.7 dB
Output power (Down/Up):17.4 dBm / 12.5 dBm
FEC Events (Down/Up):17670747 / 3974
CRC Events (Down/Up):71 / 82
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):239 / 101
Error Seconds (Local/Remote):45 / 24
Best regards,
dfenceman
Message 23 of 49
looks like back to before with noise margin dropping that low that it may trigger a reset  interleaving is working hard going by number of FEC errors
Expert
Message 24 of 49
Good morning imjolly,
I received the call back from BT at about 16:10 yesterday.  I emailed him earlier in the day with my questions in the hope that he would check things out before ringing; no such luck. So I ended up on the phone for half an hour and got absolutely nowhere.  When I tried to come on here I found my session had ended which meant a disconnection.  When I check this morning it happenned at about 16:10.  Coincidence or did the BT chap cause it ?
Net result, my speed is down, viz :-
ADSL Line Status
Connection time:0 days, 14:14:55
Downstream:2.523 Mbps
Upstream:784 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.1 dB / 6.4 dB
Line attenuation (Down/Up):57.9 dB / 33.7 dB
Output power (Down/Up):17.2 dBm / 12.6 dBm
FEC Events (Down/Up):7117 / 2413
CRC Events (Down/Up):29 / 51
HEC Events (Down/Up):127 / 55
Error Seconds (Local/Remote):89 / 51
Best regards,
dfenceman
Message 25 of 49
on plus side you have 14hrs connection time with good noise margin and nowhere near as many errors as before
Expert
Message 26 of 49
The BT advisor refused to tell me whether he triggered the reset.  He also refused to pay the travelling expenses as I could not give him the name of the advisor that promised to pay them.  Unfortunately even if they give a name it is never understandable as is oftern the case in view of the accent difference, in both directions.
I suppose in the final alalysis a decent broadband connection is more important.   Things not looking too bad, although the FEC events are still higher than "normal", viz :-
ADSL Line Status
Connection time:1 days, 17:23:15
Upstream:784 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.2 dB / 6.5 dB
FEC Events (Down/Up):35380 / 8333
CRC Events (Down/Up):69 / 67
HEC Events (Down/Up):489 / 90
Error Seconds (Local/Remote):110 / 64
Changing subject, SFBB has made a step forward as people have seen fibre being laid in places between the village and the exchange, plus our PCP was replaced yesterday as planned
Best regards,
dfenceman
Message 27 of 49
stats looking back to more like you had before this last disconnection episode started.
don't know what label is - maybe this cab 7 of 7
Message 28 of 49
the label is just a manufacturer's reference sticker and of no consequence
Expert
Message 29 of 49
Hi imjolly & john46,
Many thanks for the replies.  It is PCP2, PCP7 is in another village, so that's what made me query it.
Best regards,
dfenceman
Expert
Message 30 of 49
Two updates from emails received on Friday, one from Openreach & and the other from BT.
Openreach replied as follows with respect to our new cabinet "The shiny cabinet is a new shell for the old cabinet 2 so that extra cables can be installed from it to the new fibre cabinet.
The label gives the serial number for the cabinet."
The one from BT was from the manager the advisor that was dealing with the disconnection issue saying he would look into the issue and call me back.  No surprise that I never got the call.  However I had a disconnection soon after the email was sent.  Since then the errors have been low although the speed is down a little.
Provided things do not deteriorate again in the next week or so I will mark this thread as solved.
ADSL Line Status
Connection time:1 days, 16:23:24
Downstream:2.679 Mbps
Upstream:824.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.6 dB / 6.4 dB
Line attenuation (Down/Up):57.6 dB / 33.7 dB
Output power (Down/Up):17.3 dBm / 12.5 dBm
FEC Events (Down/Up):72759 / 7037
CRC Events (Down/Up):46 / 84
HEC Events (Down/Up):289 / 160
Error Seconds (Local/Remote):41 / 27
1. Best Effort Test: -provides background information.
 Download  Speed
 2.47 Mbps
0 Mbps4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 2.47 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 2.42 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.67 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.67Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Best regards,
dfenceman
