Message 1 of 12
No Dial Tone - CA initially returned
I have no dial tone and have been on troubleshooter, on the first test it says it needs to test again and I tick go ahead; after the second test the response is CA initially returned? Yes or No.
Come on BT give me a CHANCE; what does heck  "CA initially returned" mean?
11 REPLIES 11
Message 2 of 12
Re: No Dial Tone - CA initially returned
Have you tried using the test socket to see if you get a dial tone. If nothing there then you need to phone 151 and report phone fault
Message 3 of 12
CA= customer apparatus
Message 4 of 12
Customer Apparatus suspected as faulty. It usually means that no phone is detected or possible a faulty NTE.
Message 5 of 12
Thanks everyone for such the quick response; I tried in the master still no dial tone and my phone got an error message about a cord error, which went away when I plugged back in to the normal socket and switched the power off/on.
I'll buy a cheap corded phone tomorrow and try in both sockets
Message 6 of 12
Sorry but by 'tried master' was that actually test socket which is behind master front plate or just the master socket?
Message 7 of 12
Yes I used the socket behind the front plate - in case it makes a difference my broadband is OK
Message 8 of 12
Your phone requires both wires connected to work whereas broadband can work with only 1 wire connected but it would normally be a lot slower than normal. Maybe the problems is your actual phone
Message 9 of 12
Well I bought a corded phone and I have the same problem; no sound when I lift the receiver; with the other phone I got a slight buzz but with the corded nothing at all.
I have tried the 7 day a week chat on BT's website but of course they have no operators available. The 151 number you mentioned earlier, is it open at the weekend and when using a mobile do I need to prefix the number with anything?
Thanks for your help so far, much appreciated.
Message 10 of 12
0800 800 151
