Brinnie
Message 11 of 13
Re: No Dial Tone.
@openwm wrote:
you have a loop on your line causing the phone to think it engaged 100% sure
You may very well be right though I don't really know what might have caused that.
Is this something at my end or is it at the exchange? Tech support said that engineers are working on a fault at my exchange, one that is affecting other customers in my area too. Is what you are suggesting consistent with that?
openwm
Message 12 of 13
Re: No Dial Tone.
if its a loop on the mdf ( exchange ) then possible adsl card has gone faults tams block etc
Brinnie
Message 13 of 13
Re: No Dial Tone.
It was fixed last tuesday.
