Newbie
Message 1 of 5
No Dial Tone
What exactly produces a No Dial Tone fault on a landline.
I have a main socket wirh a BT Graphite phone plugged in there. The 3 subordinate phones are plugged into no other sockets but operate on wireless links to the main socket..
I have 3 extension lines which are NOT used. Can these non-active extension lines produce a No Dial Tone fault?
If the connection between the main socket and these extension lines is cut WITHIN the main box, will that restore the Dial Toneby itself?
Anybody got any answers?
4 REPLIES 4
Recognised Expert
Message 2 of 5
Re: No Dial Tone
There are many things that can cause a NDT, usually the two most common causes are a disconnection somewhere or a Loop, aka Short.
Do you have an NTE for your master socket, if so remove the faceplate as that should disconnect your extension wiring (unless its star wired), then try a phone into the test socket. If its still NDT after that there will be a fault out to line somewhere.
Newbie
Message 3 of 5
Re: No Dial Tone
thanks
I'm concerned with the effect of  NON-USED extensions. An engineer removed the plate then, after some work, got a dial tone. That's all I really wanted. He tested the line & said the extensions were causing interference & cut them off within the box. BT are charging me £99 because they say the extension lines were CAUSING the NDT - i.e. stopping connection with BT. Is that possible?
Message 4 of 5
Re: No Dial Tone
yes it is possible that the extensions could have caused a problem and if once the extensions were removed the dial tone returned the as the extensions are your responsibility
this is the reason for the charge
Recognised Expert
Message 5 of 5
Re: No Dial Tone
Yeah, its possible. I have been to many a job where I have found it was the customers extensions causing the fault.
