Message 1 of 4
No IPv6 (Stateless) Autoconfiguration over WiFi
I have a BT Fibre VDSL package with a Smart Hub 2
When I connect my Windows 10 Surface Book 3 to the LAN (wired ethernet to the router) the computer gets assigned (or assigns itself) an IPv6 address and public IPv6 testers (like ipv6-test.com)  recognise my IPv6 address, and I can use "ping -6 www.google.com" to check the IPv6 connectivity from inside my network.
But, when I connect via WiFi the IPv4 setup via DHCP works, but there is only "Link Local" IPv6 setup. Is this normal? I get the same behaviour (using a USB ethernet adapter) on an Android device.
In the Smart Hub 2 Advanced > IPv6 > Configuration page there is an option for IPv6 allocation mode (Stateless, Stateful, Both, Off). If I chose "Both" then my WiFi connected Windows machine gets an IPv6 address. Are there risks to this setup?
Examples of the different configurations, running ipconfig on Windows...
ipconfig output for wired connection:
C:\Users\sjmac>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix . : home
IPv6 Address. . . . . . . . . . . : 2a00:2...4e3:bf9a
Temporary IPv6 Address. . . . . . : 2a00:2...e68:5e2a
Link-local IPv6 Address . . . . . : fe80::7...f9a%16
Default Gateway . . . . . . . . . : fe80::3...c46%16
Wireless LAN adapter Local Area Connection* 1:
Media State . . . . . . . . . . . : Media disconnected
Wireless LAN adapter Local Area Connection* 2:
Wireless LAN adapter WiFi:
Link-local IPv6 Address . . . . . : fe80::a...304%20
IPv4 Address. . . . . . . . . . . : 192.168.0.93
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Bluetooth Network Connection:
If I connect the same computer to the Smart Hub (or another access point on the same network) using WiFi then I can see there is no gateway for IPv6 traffic, and public IPv6 tests show that I do not have an IPv6 link (ipv6-test.com)
ipconfig output for WiFi only:
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: No IPv6 (Stateless) Autoconfiguration over WiFi
Works fine for me via WiFi with IPv6 configuration set to Stateless.
Message 3 of 4
Don't know what's happened there. I have an SH2 which I've left set to Stateless and I get a v6 address OK when connected by Wi-Fi
Message 4 of 4
Thanks @Les-Gibson , @licquorice - that's at least helpful to know.
I have a slightly odd config with the Smart Hub IPv4 DHCP server turned off, and I have another ISP connection available via the same LAN.
At the moment traffic is split (by accident) to send all IPv4 traffic via VirginMedia, and any IPv6 traffic goes through BT. (VirginMedia don't currently route IPv6 on their residential connections.)
