SCARLYWICK
Newbie
Message 1 of 5
No Options
Hi all.  I have a BT Freelance XD 5500 phone with 4 phones.  When I make a call I cannot use the options as requested by the call receiver. eg phoned BT help line and was told to press 1 for phone faults...nothing.
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: No Options
Have you accidently changed the dial mode from tone to pulse?
1. Press menu, scroll (using calls button) to SETUP and press menu.
2. Scroll to DIAL MODE and press menu .
3. Press either Redial or Calls to select TONE or PULSE and press menu.
4. Press and hold the secrecy button to return to the standby screen.
-+-No longer a forum member-+-
SCARLYWICK
Newbie
Message 3 of 5
Re: No Options
DS You are now definately an expert. I have had this problem for months.
Many thanks
Scarlywick
Distinguished Guru
Message 4 of 5
Re: No Options
No problemSmiley Happy
knmmcewan
Newbie
Message 5 of 5
Re: No Options
I also have a XD8500Twin and keep getting cut off durring outgoing calls. Secrecy On shows. Tried hard to get rid inc batteries out. Can anyone including BT help
