Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi,
I've just received the YouView box and it doesn't recognise that I have subscribed to any additional channels, such as BT Sport. Fibre internet itself works fine, and we can still access all freeview channels and apps like Netflix. The quoted code is 'BTP-15000' at set-up, and then 'BTP-20000' when attempting to access BT Sport upon installation. I've spoken to the technical team, and have attempted the usual hard reset and updates, and that doesn't do the job.
Having just joined BT and experienced delays at every part of the sign-up process, it's a bit bemusing that we're still experiencing issues at this stage. Everything was supposed to be completed by 1st August. Any help to resolve this problem would be greatly appreciated.
Many thanks.
Solved! Go to Solution.
Hi @Chizzle Sorry you are not getting the subscription channels.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Hi John,
Thanks for your quick response. Have done so.
Cheers
Hi @Chizzle I called earlier and left a brief voicemail for you. Just to let you know that the fault with your BTTV service should now be fixed.
If you cannot view the channels you will need to Reset Your Youview Box
Post back and let me know how you get on.
Cheers
John
