TeaAndToast
Message 1 of 23
No change in speed
After 15 days waiting on the switch on, and 10 days settling in, keeping the hub on.  My speed is just the same as the day my broadband was switched on, even though the line has settled down.
Line stateConnected
Connection time0 days, 0:00:49
Downstream480 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)5.7 dB / 19.0 dB
Line attenuation (Down/Up)47.0 dB / 25.0 dB
Output power (Down/Up)15.6 dBm / 12.6 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)0
22 REPLIES 22
Message 2 of 23
Re: No change in speed
Your connection speed should be about 5536Kbs but something is restricting it.
Which type of master socket do you have, and are you plugged directly into it?
One of these
Or one of these
Or if you are lucky
One of these
TeaAndToast
Message 3 of 23
Thats what I'm thinking Keith, and I'm in the middle.  I'm basically back in the parents for a few months, where I did have internet before.  I'm on a wired conntection to the same socket.  I cannot get to the master socket as its in the living room.
TeaAndToast
Message 4 of 23
Rang BT and actually got a very helpful person.  Did a line test and there is a circuit breakdown at the exchange which is due to be fixed tomorrow. All's well that ends well.... I hope.   Thanks Keith.
Message 5 of 23
Well I hope that is the problem. Your noise margin is quite low for your connection speed, which means that there is something limiting the bandwidth, either noise, or something causing a loss of signal at your end.
A phone or Sky box without a filter is usually the problem.
If you still have problems, perhaps you can explain what else you have connected to your line.
TeaAndToast
Message 6 of 23
Just came back to inform.  I found a phone without a filter hidden out of view.  Whats a house with 2 people need 6 phones for anyhow?  Im up from 3.5 to 4.1 thus far.  Have a nice Sunday.
Message 7 of 23
I did wonder. Hopefully that has fixed the problem.
Message 8 of 23
Well spotted T&T
TeaAndToast
Message 9 of 23
Just A quick update.  I noticed some lag over the last few days so reset my modem when it got to 3mb, now it won't go past 2.5mb. I can see the noise line down has risen and the up has done nothing.  I have also did a line check from a cordless (which is all I have) and there doesnt seem to be anu noise.  I also went around and opened all sockets, and there is no test socket.  Any ideas?
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:00:41
Downstream2,592 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)12.6 dB / 22.0 dB
Output power (Down/Up)17.3 dBm / 12.5 dBm
FEC Errors (Down/Up)16 / 0
Message 10 of 23
looks like the exchnage has ben a bit aggressive on your connection due to a few resets recently and moved your noise margin to 12.6 with the resulting drop in connection speed.  you now need to leave and get 3+ days connection and if noise margin still above normal 6db then conatct the mods and get it reset to 6 with corresponding speed increase
