TeaAndToast
Message 11 of 23
Re: No change in speed
Whats I was thinking Jolly, less it more sometimes.
Thanks mate
TeaAndToast
Message 12 of 23
I have left my connection on a right few days and there is no drop in noise margin, which was 6 ish, but after a few resets due to my egerness I'm not sitting around 12 before and after remaining connected a few days.  Could a Mod contact me to arrange a reset please.
Kind Regards
T&T
Message 13 of 23
need to post your stats to show stable connection before getting noise margin reset. after 3+ days stable connection you can contact the mods - they will not contact you first
Message 14 of 23
Hi T & T this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
Message 15 of 23
They  like to see at least 3 days stable connection before the reset
TeaAndToast
Message 16 of 23
Thnaks again J&J - Just reset my moden today, another 3 days it is.
Thanks very much - again.
TeaAndToast
Message 17 of 23
Here are my line stats after 3 days for the admins.  It took so long to post back because the line had dropped a few times, in that the blue broadband light went off twice, then on another two occasions the whole hub just rebooted and started flashing the power light > wifi > broadband.
Line stateConnected
Connection time3 days, 5:58:26
Downstream3,264 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)12.4 dB / 12.0 dB
Line attenuation (Down/Up)47.0 dB / 25.0 dB
Output power (Down/Up)17.8 dBm / 12.6 dBm
Loss of Framing (Local)34
Loss of Signal (Local)3
Loss of Power (Local)0
FEC Errors (Down/Up)253197 / 39
CRC Errors (Down/Up)1824 / N/A
HEC Errors (Down/Up)N/A / 35
Error Seconds (Local)1682
Message 18 of 23
Hi T& T
 looking much better now
TeaAndToast
Message 19 of 23
12.6/22 was the previous John, so only the up has settled. Slight improvement today.
Line state Connected
Connection time 4 days, 0:06:47
Downstream 3,264 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 11.7 dB / 12.0 dB
Line attenuation (Down/Up) 47.0 dB / 25.0 dB
Output power (Down/Up) 17.8 dBm / 12.6 dBm
Loss of Framing (Local) 34
Loss of Signal (Local) 3
Loss of Power (Local) 0
FEC Errors (Down/Up) 260223 / 40
CRC Errors (Down/Up) 2112 / N/A
HEC Errors (Down/Up) N/A / 36
Error Seconds (Local) 1883
Message 20 of 23
did you contact the mods to get noise margin reset to 6 as you can now show a stable connection of 4+ days?
contact mods
can take up to 3 working days for mods to contact you
