Most likely an exchange line card fault. If you have reported the fault to BT, then they should be able to fix it. Provided that you have proven that the phone is not faulty. Report it as no incoming calls, if you have not done already.
Your line will need to be moved to a different piece of equipment in the exchange, this will be done by an Openreach Frame Technician as soon as someone picks up the task.
