Message 1 of 4
No internet and Openreach modem power status remains flashing
Hi all,
Yesterday my internet cut out - I have fibre to the property in a new build. Router itself was fine but the BBU had a red fault light on. I did a power cycle on the modem as suggested by the troubleshooting guides, this causes the BBU fault light to turn off but the modem never gets to a stable green state, the power LED just remains blinking, all other lights are off, almost like it gets stuck booting? I left it on overnight to see if it would resolve itself but even after 10+ hours the modem remains in this state.
Is there anything else I can do to try and fix this myself? Perhaps attach a computer to see logs or similar?
Thanks!
3 REPLIES 3
Message 2 of 4
Re: No internet and Openreach modem power status remains flashing
@edb1
Try bypassing the BBU. Also, have you checked that there is power going into the ONT as it could be that the power unit has failed.
Message 3 of 4
Thanks Keith, good news! I bypassed the BBU with no change, but then tried a different power adapter I had lying around - this fixed the issue! I guess the original power adapter was damaged somehow?
Appreciate your fast response!
Message 4 of 4
You could request a replacement power supply unit, if you explain the problem to the FTTP team. I believe there was a batch of power units which prematurely failed.
