hurryup
Message 1 of 4
No internet light on voyager router
Hi. My broadband has not been working for nearly a month. I had perfect connection with a voyager 210 router since 2006 which I think packed in altogether because  all the lights went out on it eventually but I had trouble with it for 2 weeks before that. I bought another 210 but cant get connected with it at all. The all the lights are on apart from the internet light and LAN is showing as connected too. The helpline are saying its because the router is an old model and have said they are sending a homehub. I have tried everything they said. Will this hub work or is it to do with router configuration? (which i feel, altough im clueless)
3 REPLIES 3
hamish72
Recognised Expert
Message 2 of 4
Re: No internet light on voyager router
With the hub all you should need to enter is the BT user name  all else is normally set up ready but if you read the forum the consensus is DO NOT USE the supplied CD to set it up
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Distinguished Guru
Message 3 of 4
The BT Homehub requires no set up, connect up the power supply and just plug it into your ADSL filter and plug an ethernet cable from the hub into the PC.
If you want help with wireless set up have a look here
Can I suggest that you replace the ADSL filters you have with the ones supplied with the new hub, incase that is what is causing your problem.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
hurryup
Message 4 of 4
Thanks for the replies.  Its not the adsl filters because I unplugged the other phones from their sockets to test this and the result was the same. Homefully the homehub will get things working.
