Ronnie234567
Message 1 of 4
No mobile USA
Can anyone help, I'm in the USA, but my bt mobile won't work. It says "no service". All my family are on BT, and have the same problem.
Tags (1)
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: No mobile USA
Did you enable roaming and Intenational calls before you left the UK? Its done via MyBT.
PaddyB
Moderator
Moderator
Message 3 of 4
Re: No mobile USA
Hi @Ronnie234567,
If you take a look at How do I use BT Mobile abroad? you'll find a few details.
Can you check as @Keith_Beddoe has suggested and make sure that International Calling has been turned on. You can do this by log in to www.bt.com/mymobile >
PaddyB
Ronnie234567
Message 4 of 4
Re: No mobile USA
Thanks guys your lifesavers, all working now. I must of blocked international calls and forgot. I turned it back on under my by BT.
I had to go into iPhone settings and turn off automatic carrier selection, once I selected T-Mobile it started working.
Thanks again!
