Danoid
Message 1 of 4
No sound
Hello
I have a dtrt2110 with latest firmware 15 jan 2017, manufacturer software 26.40.4
Sometimes when turning the box on I have no sound, if i put it into standby and turn it back on i still have no sound.
So i have to turn off by the switch at the back, when it turns back on i have sound.
So this is obviously a bug or issue with my box.
Its done it twice now but wondering whats going on?
3 REPLIES 3
speedtrip
Expert
Message 2 of 4
Re: No sound
Are you using the TV speakers via HDMI cable, or are you using a SoundBar via the SPIDF (Optical) cable ?
I use the latter on my G4 YV DTRT2100 box and frequently the sound goes when changing Channels - total PitA to have to power it off & on again to restore the sound !
Seems OK when I revert to TV speakers - ie just use the HDMI cable ...
Danoid
Message 3 of 4
Re: No sound
Just audio over hdmi.
I have set my remote to learn the tv, but even changing the sound by tv remote is still the same.
Next time i might try removinh hdmi from tv then plug back in, just incase its somehow my lead but doubtful
skappy70
Recognised Expert
Message 4 of 4
Re: No sound
Try either of these two, removing HDMI cable from box for 5 secs or in Settings toggle the HDMI output from 1080 to 720 or vice versa as this blips the HDMI port on the box.
