Message 1 of 9
No speed increase after upgrading to Infinity 2
Hi upgraded and was supposed to be live on wednesday. checked speeds after reboots each day but no speed increase?
DSL uptime:0 days,00 Hours06 Mins39 Secs
Data rate:11.283 Mbps / 47.316 Mbps
Maximum data rate:11.386 Mbps / 47.801 Mbps
Noise margin:6.1 / 6.1
Line attenuation:19.2 / 16.8
Signal attenuation:19.0 / 16.8
thanks
8 REPLIES 8
Message 2 of 9
Re: No speed increase after upgrading to Infinity 2
@lee74
Perhaps your line cannot support a faster speed, did you check before upgrading?
The upload speed increase indicates you have been upgraded.
Check here to see what your line can support.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Message 3 of 9
we had fibre 2 about 5 years ago. We was getting between 69 -71 . we chose fibre 1 when we came back to bt and decided to upgrade at the end of the contract
Message 4 of 9
Message 5 of 9
Have to tried connecting to the test socket, just in case your internal wiring is affecting the connection speed?
Message 6 of 9
Hi Keith,
Thanks for the replies! Yes tried test socket , went through the forum before posting. Seems others that have had the issue have put it down to being stuck on fibre 1 profile. Problem seems to be getting bt to look at this??
Message 7 of 9
You are not stuck on fibre1 profile, your speed is less than the cap.
Message 8 of 9
what do you mean? The stats are exactly the same give or take as Monday - Friday despite moving to fibre 2 on Wednesday?
Message 9 of 9
If your speed was below the cap for fibre1 previously, moving to fibre2 won't increase it. You can't be wrongly capped at fibre 1 speed because you aren't even reaching the maximum, your speed would be 55 if your line was capable of faster but capped.
