Message 1 of 13
No valid IP configuration
Hi, I have a problem - Im connected with pc to hub with cable, but there is no internet connection. When I tried to troubleshoot the problem it says that there is no valid IP configuration.
I tried reset hub and modem... tried to unplug it from power - nothing helps.
Also I have two laptops - connected trough wi-fi - they working fine. Before Christmas all devices was connected fine - now I cant get connected my pc trough cable and 2 mobile phones trough wi-fi. Seems that in my house is 2 IP left.
How to solve this?
Im in New Cross Gate
Regards Girts
12 REPLIES 12
Recognised Expert
Message 2 of 13
Re: No valid IP configuration
Have you checked your Network connections settings, make sure that the IP4 Properties are set to Obtain an IP address automatically.
Message 3 of 13
Hi, Yes everything is set to automatically.
Recognised Expert
Message 4 of 13
Please could you post a screenshot of the Network connection details, thank you.
Message 5 of 13
Recognised Expert
Message 6 of 13
Sorry, the details, once you have the Local area connections status up, click details and post that, thank you.
Message 7 of 13
Recognised Expert
Message 8 of 13
It shows that it is not picking up the IP address from the homehub, have you tried a different network cable?
Message 9 of 13
No, but yesterday everything was fine before I restarted my pc
Recognised Expert
Message 10 of 13
Could be a cable fault or have you tried using a different network port on the homehub. If you have not tried these then try them and see if that makes a difference, if not then you have a faulty homehub.
