Message 91 of 117
NOT A HAPPY BUNNY!!!
I'm home now, no call or email OR PM from any of the moderators and I know they go off at 9pm.....
If there on at all now I will be suprised!
Nothing has changed, all the same.....I'm past the point of anger......bit of a joke really.If something BAD has happened then I will take everything back THAT IVE SAID REGARDING- NOT BEING CONTACTED TODAY.
Shame on you BT.
If there isnt a reason why I have not been contacted and I've just been forgotten about- I will take my service else where and go through SKY for phone and Broadband.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:2 days, 08:13:58
Downstream:1.125 Mbps
Upstream:448 Kbps
11:49:57, 03 May.(40961.280000) ETHoA is up - VPI: 0, VCI:35
11:49:57, 03 May.(40961.280000) DSL is up
11:49:55, 03 May.(40959.810000) DSL noise margin: 18.00 dB upstream, 12.00 dB downstream
11:49:55, 03 May.(40959.740000) DSL line rate: 448 Kbps upstream, 1152 Kbps downstream
Message 92 of 117
Re: NOT A HAPPY BUNNY!!!
I wonder if the mod made a mistake when she said Monday forgetting that it was a bank holiday and she was off - just a thought
Message 93 of 117
Line state: Connected
Connection time: 0 days, 08:22:12
Downstream: 960 Kbps
Upstream: 448 Kbps
23:20:52, 05 May. ( 89.730000) ETHoA is up - VPI: 0, VCI:35
23:20:52, 05 May. ( 89.730000) DSL is up
23:20:50, 05 May. ( 88.300000) DSL noise margin: 19.00 dB upstream, 12.10 dB downstream
23:20:50, 05 May. ( 88.140000) DSL line rate: 448 Kbps upstream, 960 Kbps downstream
Hub reset during the night to the above
Message 94 of 117
1. Best Effort Test: -provides background information.
Download Speed
0.82 Mbps
0 Mbps 1 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.82 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-1 Mbps.
IP Profile for your line is - 0.85 Mbps
2. Upstream Test: -provides background information.
Upload Speed
0.37 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Message 95 of 117
worsed its been!
Message 96 of 117
another attempt to reset noise margin tha failed?  hopefully mod will contact you today to update on progress and why taking so long to get your noise margin reset
Message 97 of 117
Mod contacted me and said "sorry for not contacting you yesterday and the resets have just made your speeds worse which is worrying" so a engineer is coming out 2morow between 1-6pm to hopefully fix this.
Message 98 of 117
look forward to update tomorrow
Message 99 of 117
yup, will keep you posted.Thanks guys for your efforts!
Message 100 of 117
quick update- engineer has been, changed sockets and new connections at exchange.....seems good enough now!? I'm speaking to my Mod soon- 6 oclock is great if you can like planned.BT guy was here at 12.30am lucky i wasnt at the shop or driving!!! everytime I was getting my noise margin reduced to 6 it got worse, BT man said it might be better with a 9db setting.
Keep you posted guys
