embattle
Message 1 of 2
Noise Margin Etc
I was wonder if these figures are considered good for BT Infinity, in essence what are good figures for Noise, attenuation, etc?
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 03:39:16
6. Data rate:9999 / 39952
7. Maximum data rate:20090 / 66120
8. Noise margin:13.0 / 13.2
9. Line attenuation:19.0 / 15.4
10. Signal attenuation:
19.0 / 15.4
I'm mainly asking because the main sock has a few links in it that could cause future issues.
1 REPLY 1
imjolly
Message 2 of 2
Re: Noise Margin Etc
You have the max connection for infinity 1 and as you attainable is greater than infinity 1 max then it is expected your noise margin will be higher than the normal 6 dub. There is no way to say how much greater though
