Recently , in the last few days , the noise margin shown in my Smart Hub shows as 12 which is double what it used to be.
Obviously my connection speed has suffered accordingly.
My question is , can anything be done about this or will it sort itself eventually ?
Who can say until you post the stats? Not just the noise margin but Data rate, Max Data rate, noise margin and line attenuation.
Post the above and someone should be able to advise further.
Meanwhile try a quiet line test with a corded phone 17070 option 2.
Product name:
BT Hub 6A
+084319+NQ62918554
SG4B10002244
06-Dec-2016
1.0
1.32.0
0 Days, 7 Hours 27 Minutes 17 Seconds
5.09 kbps / 22.40 kbps
5093 / 30697
6.4 / 11.9
27.1
Hope there is enough info here.
@Black_Infinity I'm sorry to see you're having connection problems. I can see the up time on your router stats is showing just over 7 hours. Has the connection been dropping out? Also can you try the quite line test to see if you've any noise on the line.
I can beat that ! I have a problem uploading although my upload speed is 20kbps....
@Marbella411If you have a problem you want assistance with then start you own thread.
I'm already in touch with the BT Care team and spoke to them earlier today and am awaiting the results of their tests/investigations.
Thanks for the replies
Quiet line test is indeed quiet.
Router does not usually reset often. Since using the Smart Hub I only usually see a reset on maybe a weekly basis or more.
The only thing I noticed to be different was the noise margin.
Connection speed seems to be reducing even more since Noise Margin has increased to 13+
Up untill now , I have had a solid 26 connection. I am now down to 17 😞
05:31:46, 15 Dec.
ptm0.101:VLAN VLAN_DATA connected
05:31:45, 15 Dec.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
05:31:45, 15 Dec.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
05:31:45, 15 Dec.
dsl:VDSL link Up: Down Rate=30208Kbps, Up Rate=5086Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
05:31:31, 15 Dec.
:VLAN VLAN_DATA disconnected
05:31:20, 15 Dec.
dsl:VDSL Link Down: duration was 70824 seconds
09:51:35, 14 Dec.
:WAN: SENSING AUTO VDSL
09:50:56, 14 Dec.
09:50:56, 14 Dec.
09:50:56, 14 Dec.
09:50:56, 14 Dec.
dsl:VDSL link Up: Down Rate=30697Kbps, Up Rate=5093Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
09:50:39, 14 Dec.
09:50:31, 14 Dec.
dsl:VDSL Link Down: duration was 97790 seconds
06:41:12, 13 Dec.
06:40:42, 13 Dec.
06:40:42, 13 Dec.
06:40:42, 13 Dec.
06:40:41, 13 Dec.
dsl:VDSL link Up: Down Rate=24698Kbps, Up Rate=5119Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
06:40:27, 13 Dec.
06:40:17, 13 Dec.
dsl:VDSL Link Down: duration was 21815 seconds
00:02:01, 01 Jan.
00:01:19, 01 Jan.
00:01:19, 01 Jan.
00:01:19, 01 Jan.
00:01:19, 01 Jan.
dsl:VDSL link Up: Down Rate=30115Kbps, Up Rate=5160Kbps, SNR Margin Down=6.00dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
:WAN: ethernet as LAN
00:34:50, 13 Dec.
dsl:VDSL Link Down: duration was 29482 seconds
00:34:50, 13 Dec.
00:01:54, 01 Jan.
00:01:28, 01 Jan.
00:01:28, 01 Jan.
00:01:28, 01 Jan.
00:01:28, 01 Jan.
dsl:VDSL link Up: Down Rate=28558Kbps, Up Rate=4992Kbps, SNR Margin Down=6.00dB, SNR Margin Up=6.70dB
00:00:22, 01 Jan.
