gobin99
Message 1 of 8
Noise margin
Hi,
I had 5.5MB connection, until BT upograded my exchange, ACCRINGTON a few weeks ago.
My connection was 9.5Mb for a few days, but by the end of the 10 days it had dropped as my V1 Hub was re-setting constantly.
I spoke to BT who sent me a new v2 Hub. which has been connected directly to the test socket.
My noise margin is high and does not seem to be dropping, and I assume this is why mt IP profile has been set to 1750
I have atatched my router stats, an speedteser results(The errors were from me removing the fromt plate on my BT socket to get to the test socket. They have not increased at all for over 5 days)
What can I do to improve my speed?  I apprieciate any help you can offer.
ADSL line status
Connection information
Line stateConnected
Connection time5 days, 6:41:34
Downstream2,268 Kbps
Upstream1,240 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)29.4 dB / 5.6 dB
Line attenuation (Down/Up)16.0 dB / 7.0 dB
Output power (Down/Up)0.0 dBm / 12.3 dBm
Loss of Framing (Local)10
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 4294967263
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)2
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
1879 Kbps
0 Kbps2000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 1879 Kbps
 For your connection, the acceptable range of speedsis 800-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :2268 Kbps(DOWN-STREAM), 1239 Kbps(UP-STREAM)
 IP Profile for your line is - 1750 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.36:30.0:56.65 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
1024 Kbps
0 Kbps1239 Kbps
>Upload speed achieved during the test was - 1024 Kbps
 Upstream Rate IP profile on your line is - 1239 Kbps
We were unable to identify any performance problem with your service at this time.
7 REPLIES 7
geaves
Expert
Message 2 of 8
Re: Noise margin
You could try emailing the mods forum.moderation.team@bt.com with a link to your post, your account number and your phone number, I have found them to be very helpful.
gobin99
Message 3 of 8
Re: Noise margin
Thanks for the advice, I have emailed them and I will see what response I get.
RubberNutter
Message 4 of 8
Re: Noise margin
Hi
For your atten of 16 db you should get between 16 to 20 odd meg of your line, the high noise margin is what is killing the speed, do you have any noise on the telephone line, try 17070 option2 for quiet test, if it is noisy then you need to report that.
Since you are in the test socket, try swapping the filter over ensure filter first, swapped the RJ11 cable ends around, it seems there is something stopping the service getting up too speed, usually the BRAS ip profile starts to configure the line within 3 - 5 days and DLM should take care of the noise margin and bring it back down.
I would suggest calling BT and get a line test ran as well as you may have a fault on your line.
Guru
Message 5 of 8
Re: Noise margin
DLM won't bring noise margins down.
Curing impulse noise (if pssible) brings margins down.
DLM sets the line speed according to the attenuation, fault error levels/timeframe and margin level.   😉
gobin99
Message 6 of 8
Re: Noise margin
I have tried the quiet line test and it seems clear, no noticeable noise at all.
I have changed the filter for the other one that came with the new hub, and swapped the RJ11 cable round.
Where do I go from here ?
ADSL line status
Line stateConnected
Connection time0 days, 0:07:39
Upstream1,236 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)29.6 dB / 6.3 dB
Line attenuation (Down/Up)16.0 dB / 7.1 dB
Output power (Down/Up)0.0 dBm / 12.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
FEC Errors (Down/Up)0 / 0
HEC Errors (Down/Up)nil / 12
Error Seconds (Local)0
Guru
Message 7 of 8
Re: Noise margin
Now just leave it alone ... connected 24/7, no more resets.
See if any improvement takes place.
Could take up to 5 days.
gobin99
Message 8 of 8
Re: Noise margin
Will do.
Thanks for the assistance
