Message 1 of 16
Nokia FTTP ONT with 3rd party router
Got upgraded to FTTP last week and now have one of the Nokia Openreach ONT's bring the fibre line into the property. Due to the severe limitations of the Smarthub 2 I'm looking to use my own choice of gear.
Does anyone know if you can connect a router directly to the ONT and just use PPPOE log in to access the internet or do you still have somehow have the Smarthub involved.
Think if getting an Orbi mesh system in place.
15 REPLIES 15
Message 2 of 16
Re: Nokia FTTP ONT with 3rd party router
You should be able to connect your own router to ONT and set username as [email protected] and password anything but many just use BT
if you have digital voice that will only work with SH2 connected to ONT
Message 3 of 16
Thanks for that. Deliberately cancelled the digital voice as I knew it was something that would lock me into the SH2. Just kept the copper line for the phone.
Message 4 of 16
@imjolly
Just for future reference as I suppose I'll be in this position sometime soon, does it have to be through the SH2 or would an ordinary phone work if plugged directly into the Tel socket on the ONT?
Message 5 of 16
No TEL socket on the ONT.
Either Digital Voice via Smart Hub 2 or plug into copper fed landline socket.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 6 of 16
Digital Voice only works via the SH2. The Tel socket on the ONT is for the now discontinued FVA, fibre voice access.
Message 7 of 16
I have used Orbi Mesh with my ONT- works with no problem.
Message 8 of 16
Thanks for that imjolly/liquorice.
Sorry for hijacking the thread but just one more question then, if I may. Would it be possible to connect my own router to the ONT via a switch and then plug the SH2 into the switch to provide DV?
If DV only works through the BT's hub this seems a bit of a marketing blunder on BT's part.  A lot of people are going to want to run their own kit these days so I can see that killing DV at birth.
Message 9 of 16
If and when you are switched to DV your copper landline will no longer work
Message 10 of 16
No, you can't do that. You can only connect one router directly to the ONT.
Not everyone wants a landline voice service, most people use mobiles for voice calls. Digital Voice is just BT's VOIP service, there is nothing preventing you using a third party VOIP provider with your third party kit.
