Guru
Guru
Message 11 of 13
Re: Non standard BT socket causing slow broadband speed?
Hi Hayley040904,
Are you a BT Retail customer? as this forum is for BT Retail customers.
It could be that the phone socket currently in use is the Master socket if the property used to have more than one line.
The property should have it's own dedicated line, unless a DACS unit was used. However broadband shouldn't work if a DACS unit is on the line.
To upload a picture you need to click the "Tree" icon when creating a post and then browse for the image you want ot upload.
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
shirts
Recognised Expert
Message 12 of 13
Can you post the picture of the socket ? Not sure if you can do that from a mobile.......(in the reply box, there is a small picture of a tree........)
Oops......sorry Jac95......great minds think alike......Smiley Wink
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
duncan10
Expert
Message 13 of 13
Haley . If the house is split in 2 and your part doesn't contain the original line in master socket. Then you might have to pay an installation charge. It depends if the other tenant in the other part of the  house has a line installed--USING EXISTING  external O/H wiring and UG pair. If not the O/H could be diverted to you . The BT engineer arriving on-site would advise.
