lovelylisa22
Message 1 of 15
Normal to only have one hub restart since going on ADSL2+ on the 26th?
When I first started out I had numerous hub restarts while my line was stabilised but since going on ADSL2+ on the 26th I've only had one.  It did increase the speed very slighty but I've had no more since then.
14 REPLIES 14
john46
Message 2 of 15
Re: Normal to only have one hub restart since going on ADSL2+ on the 26th?
just be patient and let the 10 day training period complete
lovelylisa22
Message 3 of 15
I have no problem I just thought it would be restarting a lot more than it has.
I had about 3 restarts a day when they stabilised the ADSL max connection that's why I'm wondering.
imjolly
Message 4 of 15
your connection looks good from the last set of stats you posted apart from error seconds which were high but you are on fast at present.  just stick with it as you have had a great result for your efforts
lovelylisa22
Message 5 of 15
That's good I was just looking at the errors myself and they are going up and up but that's normal I suppose for the ten day period.
So far my download speeds haven't dipped below 1.1MB/s and have peaked at 1.3MB/s which is the fastest speed I've ever had since getting online all these years 🙂
john46
Message 6 of 15
leaving as it is for now interleaving may come on automatically if not and you start to have any problems the we can get the mods involved to get it turned on
lovelylisa22
Message 7 of 15
It has always been on fast if I remember rightly. So fast only works with max not 2?
john46
Message 8 of 15
it is used on all versions of broadband do not worry about it if it is needed to stabilise your line it will come on automatically if it does not and you start getting disconnections you can get the mods to turn it on
imjolly
Message 9 of 15
from the last set of stats your crc/hec errors were ok so just check when you look at your stats if still on fast the the crc/hec errors are not increasing rapidly as that will slow down  your download speed
you must be getting good at reading the stats now Smiley Wink
lovelylisa22
Message 10 of 15
Can you have a quick look and compare them for me please?  I don't know how fast they should increase etc.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:2 days, 00:31:25
Downstream:12.52 Mbps
Upstream:1.152 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):5.4 dB / 5.7 dB
Line attenuation (Down/Up):28.4 dB / 13.7 dB
Output power (Down/Up):20.4 dBm / 12.0 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):928205 / 222
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):2733960 / 194
Error Seconds (Local/Remote):129162 / 519
